Change spud diameter on 1-pipe steam radiator?
Hi all, I've got a 1-pipe steam system.
A previous owner removed two radiators from either end of a ~15' x 40' room. One end of the room is closer to the main with a 2" pipe, the other end is near the return with a 1" pipe. I've got the radiator with the larger spud size, but I'd like to reinstall it onto the smaller pipe.
Is it possible to swap out the larger union for a smaller one? If so, what parts would I need to look for? Thanks in advance!
  • jbmoff
    jbmoff Member Posts: 89
    edited October 2023
    Is that rad with the larger spud BIGGER than the other one? Most piping is sized by the rad size and its EDR.
    EBEBRATT-Ed Member Posts: 20,236
    The spud in the radiator has to match the valve. In other words the spud and the valve are a matched set. Unless you have the original valve to go with the radiator spud you need to buy a new valve and spud . They are sold as a matched set.
    mattmia2EdTheHeaterMan
  • rainbowlazer
    rainbowlazer Member Posts: 3
    Right, it's no problem getting the right size valve/spud, the issue is that the pipe where the radiator used to be is a smaller diameter than the current spud. I'm pretty sure it's the right size rad for the location as it matches ones in adjoining rooms.
    So I think what I'm imagining is removing the bushing from the radiator, swapping it out with one that will accommodate the right size spud. Does that seem like a good idea?
    mattmia2 Member Posts: 16,895
    Check to see if the bushing is left had thread. In radiators that used left/right nipples to hold the sections together sometimes the bushing would be left hand thread. Other than that you can remove the bushing. You would probably have to carefully cut 2 slots almost down to the threads then knock out the wedge between them with a small chisel to get it out.
    EdTheHeaterMan Member Posts: 12,284
    If I am reading this correctly. You have a radiator with a 1-1/4 spud inserted into the 1-1/4 female tapping in the radiator. If that is correct then you should remove the 1-1/4 Spud and install a 1-1/4 x 1 bushing in the radiator and then use a new valve that comes with the matching spud.
    If you are worried about leaving some water left in the radiator because of the dimension of the bushing, I would say that is already happening anyway, so what's another 1/4" of water going to do?
    mattmia2EBEBRATT-Edrainbowlazer
    Or if you have the 1 1/4 valve and the spud that match and were originally a matched set just put a 1 1/4 x 1 bushing into the bottom inlet connection to the valve and raise the radiator up on some shims
    EdTheHeaterManrainbowlazer
    ethicalpaul Member Posts: 8,863
    maybe "ping...ping...ping...ping"
    edited October 2023
    As opposed to the "Ping.......ping........ping" of the existing bushing that goes to 1-1/4? Or does 1-1/4 go "Pong..... Pong..... Pong". There is always some water at the bottom of every radiator, they don't drain like a bath tub Paul. If you had a glass section in one of those radiators of yours, you could see that. LOL
    OOPS... Now Paul will be on line looking for a glass radiator to connect to his system to watch the condensate drain from it.
    mattmia2bburdCLamb
    Maybe the "Dead Men" should have made the radiators with a bottom inlet
    CLamb
    Or used an offset bushing.
