Steam vs hot water Radiator Valves
So I have a couple rads that have shut off valves from Home Depot that I was told are for a hot water system. I do have some steam valves that are just a little fatter but I cant tell the difference between the different valves with the way they perform. Can someone explain?
    There are critical differences inside the valve. The steam valve is built in such a way that water can drain freely and completely through it when it is opened. The hot water valve is built somewhat diffeerently, and has a smaller opening (sometimes much smaller) and unless the valve is oriented just so will not let water (condensate) drain back through it readily, even if it is opened.
    itzaseanmattmia2
  • dko
    dko Member Posts: 669
    edited September 2023
    Are you sure you didn't just buy a steam radiator valve and the guy just said it'll also work for hot water? (you can- preferably the white ptfe disc, just not vice versa)
    I don't see home depot have any hot water radiator valves in stock
    but here's a youtube video showing the difference
    https://www.youtube.com/watch?v=sAPK_txfTxQ
    itzasean
  • ordellrobbie
    ordellrobbie Member Posts: 22
    I think you can use a steam radiator valve on hot water. You definitely can’t use hot water on steam.
