Radiators getting hot when only need hot water
I have an old boiler (oil hot water), domestic HW, radiators, and a RA89a transformer. With nothing being changed on the system, now when the system calls for hot water, the radiators get hot. I don't need heat, it's 70 degrees out. I just need hot water. Any help appreciated.
    mattmia2 Member Posts: 17,466
    edited September 2023
    Are the radiators steam or hot water? Show us a good picture of one or of the boiler if you don't know. We will probably need a good boiler picture capturing the controls and the piping anyhow.
    Edit, oh you said "oil hot water" so it is hot water.
    What @EBEBRATT-Ed said. Or possibly a stuck zone valve. Or a flow check valve that was manually opened during some sort of service and wasn't closed again.
    EBEBRATT-Ed Member Posts: 20,476
    If it is a hot water boiler you probably have a bad flow check valve.
    Need some pictures to be more specific.
    mattmia2Intplm.
  • fueloilrich631
    fueloilrich631 Member Posts: 16
    Just spitballing here based off of limited info provided, but it sounds like you have a bad flo-valve
    Intplm.
    ethicalpaul Member Posts: 8,930
    Save yourself all this and install a standalone water heater and turn off your boiler in the summer.
    Intplm.mattmia2
