Its on every plumbing exam.......
«1
  • neilc
    neilc Posts: 3,207
    don't paint the pvc ?
    known to beat dead horses
    Mad Dog_2
    EBEBRATT-Ed Posts: 21,100
    LH thread
  • Mad Dog_2
    Mad Dog_2 Posts: 8,744
    Kennedy-Tucker Fitting...Female thread x Lead Caulked joint.  Mad Dog 🐕
    kcoppLong Beach Ed
  • JohnNY
    JohnNY Posts: 3,414
    My dad calls it a Tucker fitting. Dresser couplings made them obsolete.
    Remember Boston tees? Most people call them cleanouts now.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
    Long Beach Ed
  • kcopp
    kcopp Posts: 4,719
    You learn something new every day...
  • Dont even ask for an IBTS ferrule anymore.....
  • dko
    dko Posts: 669
    edited September 2023
    https://www.asc-es.com/products/744-tucker-connection
    cool
    never came across it before! hardly deal with threaded CI drainage fittings in general anymore
    Intplm.
  • The state plumbing exam in Washington has no trick questions and is based strictly on the UPC
  • Mad Dog_2
    The first time I heard a LTTY (long turn tee wye) called a 'Boston" was working in Long Island 🏝 mid 1990s  We didn't use that term in Plumbers Local #2 Manhattan & Bronx. Conversely, very few plumbers outside the 5 Boros called a Gang Bathroom copper water frames, "Crotons"
    (NYC is supplied by the Croton Watershed) Mad Dog 🐕
    PeteA
  • This is what we call a Boston tee in NJ
    Mad Dog_2JohnNY
  • How about a Tyler tee
  • Intplm.
    Intplm. Posts: 3,152
    This is called a Dandy cleanout in my neck of the woods
    Mad Dog_2realliveplumberJohnNY
  • Mad Dog_2
    Two-way cleanout...Does Tyler make pipe and fittings anymore?   Haven't seen them in many years.  Mad Dog 🐕
  • Mad Dog_2
    We would just call that a Cleanout tee with plug.  Mad Dog 🐕
    realliveplumber
  • Mad Dog_2
    A Boston.  Mad Dog 🐕
    MikeL_2realliveplumber
    hot_rod Posts: 28,454
    Or a double ell?
  • Funny how not even 100 miles apart and the different terminology is used.
    Mad Dog_2
    They are "mickey mouse ears" around here. Western, MA.
    I worked in the Boston area a few times. We call the sheet metal clamps used on old work metal electrical boxes "jiffy straps" around here. Dow their (Boston) it took me 15 min at the supply house counter to get across what I wanted they are "Madison Clamps" down there.
    But then we call a sandwich a "grinder" down there they are "subs" and that's only 90 miles away.
    Mad Dog_2
  • JohnNY
    JohnNY Posts: 3,414
    I recognized this immediately as a mickey (my guys' name for it). This is one of those things that wasn't around when I was running pipe so I don't have another name for it.
    Classes
    EBEBRATT-EdMad Dog_2
    mattmia2 Posts: 18,158
    Some places also call them battleships. I think in southeast michigan i've usually heard madison straps or madison bars.
    EBEBRATT-Ed
  • Mad Dog_2
    Long Sandwiches by geographic area:   Subs, Hoagie, grinders, Torpedoes, Big Vinny, Speedies, a Wedge, The Bomb, The Kitchen Sink.  Mad Dog 🐕
    realliveplumberMikeL_2PC7060
  • MikeL_2
    MikeL_2 Posts: 555
      How about adding : hero & po'boy.
    Mad Dog_2CLambPeteA
  • GGross
    GGross Posts: 2,063
    In the wholesale world we must know the correct technical name, as well as the nickname each contractor uses for each item. It gets a bit confusing to say the least, but at the end of the day everyone knows the nickname for a gas riser and that's all that really counts 😂
    dkoMad Dog_2Intplm.realliveplumber
  • Intplm.
    This thread brings something to mind.
    Is it just me?
    When I first started, when describing a tee, wasn't the only numbers you needed to describe it was the run if it was one dimension and then the branch.
    For example.......3"x2" tee. The run is three inch and the branch is two inch.
    If on the run the dimension changed then you would describe it in that fashion.
    I remember a few years ago...maybe ten years or so ago, I was corrected and almost scolded by someone much younger than me because I didn't say all of the dimensions when say thirty-five years before I would always ask for a fitting without three dimensions unless it was required, and never had a problem.
    What gives?
  • And these?
  • Intplm.
    And these?
    Oh Yeah! This little baby.
    @Alan (California Radiant) Forbes What do you call this?
    I think by now it's universal, no?
    Intplm.
  • Intplm.
    NO! lol
  • dko
    dko Posts: 669
    The newer guys don't even use those anymore, haven't sold a stud puncher in a long time too.
    They just use suspension clamp for everything
  • Intplm.
    Yes.... the Micky mouse ear hangers. Are we back to that again?
    But I use the stub insert hanger that @Alan (California Radiant) Forbes pictured above on metal studs. Or is it called something else?
    @Intplm.
    As far as tees go i started in 73 and was always taught that you put down all three dimensions when ordering a tee. but I have seen it done both ways and putting down the dimension of the second run is really not needed.......if the person filling the order knows what he is doing.
    Intplm.Mad Dog_2realliveplumberrick in Alaska
  • GGross
    GGross Posts: 2,063
    Is it just me?
    What gives?
    That is still an acceptable way to order a tee where I am from, we try to explain this to the new guys as it can be pretty confusing when you are not familiar with the product yet. You have to remember also, that not every plumber orders tees correctly and we often have to decipher shorthand to figure out what someone is actually looking for. For example today I was sent an order that asked for " 2ea - IP ball valve" and "1ea- IP adapter" with no additional context whatsoever. It doesn't really excuse the younger guy's ignorance on tees, but maybe explains why he acted that way a little bit.
    Intplm.Mad Dog_29326yssh
  • dko
    dko Posts: 669
    You win a cookie if you can guess what skaspote is
    Mad Dog_2
  • Mad Dog_2
    Yes..I remember that...The New Supply House Bullies were very adamant about that.  They probably had a National Conference and voted on it.  We also always called the copper tubing one size smaller than 1/2" Nominal, 1/2 " O.D. Basin & Toilet rank supplies we called 3/8" and so on.  One day, they all start saying.  :" you mean 15/16th??  Whatever!
    Grainger is set up like that too.  Ok, I need 1/2" Wall Armaflex for 3/4"  copper..."
    Wait...so you want 7/8" I.D.????  Maddening.
    Intplm.
  • Mad Dog_2
    Hose BITE?   SKASPOTE?  ROYGBIV?? what is the frequency Kenneth?  (Anyone remember that one??)  Mad Dog 🐕
    GGross
