Navien NCB-H and NFC-H Combi-Boilers
johnsb
in Gas Heating
My old boiler/hot water heater (Munchkin) finally broke down. I'm now using mini-splits for a lot of my heat but I obviously need a system for my hot water. One plumber recommended the Navien NCB-H and NFC-H Tankless Combi-Boilers while another insisted that I should spend considerably more for the ISB system. Any thoughts?
Navien is not a favorite around here.
The installer is 95% of the equation. Do your homework finding a good hydronic contractor.
Have you tried the contractor locator on this site?Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
