System Circulator questions
northlakes
Member Posts: 95
in Gas Heating
The Grundfos circulator (hydronic baseboard, mod-con) I currently have has been wired for constant on, my assumption has been that previous owners were concerned about pipes freezing, so they removed a zone valve to keep the perimeter loop moving (which contains a pipe run in a concrete trench crossing a garage door threshold.)
Feels like this pump is starting to make more noise than before and I’m considering getting a back up as follows:
old pump Grundfos UP 43-75-F
new pump Taco 0012-F4
I don’t know if the pump is getting too much wear from continuous use, I turn off in summer but back on in fall and it runs until spring. When/if I replace the pump I’m considering adding some kind of OD temp sensor + relay that will run the pump continuous below certain temperature, but allow it to run intermittent on heat calls above that temp.
Anyone done anything lIke this?
1
It’s 3 floors, (2 above boiler about 2500 sq ft. above and 1500 at boiler level, 2 floors above are perimeter loops only) boiler is IBC VX199. I don’t like wasting money on electric but a frozen/busted pipe could cost us far more…hot_rod said:That is a fairly large pump, what size is this system, or boiler?
Anytime you are running flow you are consuming $$0 -
Almost never lose power for more than a few minutes. I will get some pics of the equipment.pecmsg said:
@STEVEusaPA it’s a primary secondary with individual boiler circ and a system circ which is the one I want to get a replacement for. ZVC 4 zone using 3 zones now and assume I can use it to control system circ relay as well. System circ currently hardwired with on off toggle switchSTEVEusaPA said:How about some pictures/piping diagrams and what controls on your system.
- 120 Geothermal
