Recommendation for reliable, exterior, gas tankless water heater
ak540235
Member Posts: 3
Hello!
I am retrofitting a 500 sq. ft. studio (ADU) in the San Francisco Bay Area. I'd like to replace the existing water heater tank and reclaim the utility room that it's in by installing an external tankless water heater. The studio has 1 kitchen sink, 1 bathroom sink and 1 shower.
Any suggestions for which models are most reliable and suitable for exterior use for a small space?
Thank you!
Thank you!
Hi, I agree with Jamie. California is aiming to get off of gas by 2035. If you used low flow fixtures and a shower drain heat exchanger, you could probably get by nicely with a 20 gallon electric tank, which could fit under a sink or other snug places. Of course, this depends on how many people the system would serve. Just for doing some of the math, the average shower is eight minutes and low flow showerheads can be adjusted to deliver 1.5, 1 and .5 gallons per minute. This suggests a 20 gallon tank could give you about two showers. With a shower heat exchanger, easily three showers
Yours, Larry0 -
Unfortunately the space is on a single 20A circuit, so I'd have to spend quite a bit to upgrade electrical for a non-gas solution.
Right now I'm looking at EnergyStar UEF >= 0.95 rated, outdoor gas tankless water heaters.
Currently narrowed down to:
Takagi T-H3J-OS-N $979
Rinnai RU160eN $1,395
Bosch T9800 SEO 160 Outdoor $1,496
Navien NPE-180S2 $1,275
These are all overkill for my small space, but only the larger models seem to meet the EnergyStar rebate criteria. Any opinions on these models?0 -
Hi, I looked up rebates here: https://programs.dsireusa.org/system/program/detail/1274/residential-energy-efficiency-tax-credit You might double check, but all I see is a $300 tax credit. Might be tail wagging the dog... Another thought about the electric approach is to run the water heater at 120 volts. This way it draws 1/4 the power it needs at 240 volts.
Yours, Larry0 -
Thanks, Larry. Here is the rebate I'm thinking of:
https://www.energystar.gov/about/federal_tax_credits/tax_credits_homeowners/water_heaters_natural_gas_oil_propane
30% or $600 for tankless gas water heaters; ENERGY STAR models with > 0.95 UEF are eligible.
I'll get a quote for the electrical upgrade, but I think it would require a new panel and possibly even a service upgrade from PG&E.0
