What is this galvanized pipe or what was it used for?
butchball
butchball Member Posts: 1
    Jamie Hall Member Posts: 27,379
    That's an older downspout pipe, such as used to be used for gutters. What it was used for in that setting I haven't a clue, but I'd bet on a vent of some kind.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,103
    edited August 2023
    Hi, Looks like it might have been a wall furnace vent, though that should be double walled pipe. Does it exit through the roof? Is there evidence of a gas line at the base of the wall?
    Yours, Larry
    ps, As the wall is open, might be time to get rid of the knob and tube wiring. ;)
    Mad Dog_2
    mattmia2 Member Posts: 16,825
    Register box or maybe an exhaust fan.
    Mad Dog_2
    hot_rod Member Posts: 27,473
    Where is it located? If there was power to it I would guess exhaust fan
    what is the termination look like? Does it have a damper/ flapper?
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,550
    Lemme guess..right under where the stove was?  Mad Dog 🐕
    Larry Weingarten
  • JUGHNE
    JUGHNE Member Posts: 11,550
    Or it was above the stove and gave some gravity flow heat to the second floor.
    Couldn't have been much. This was usually done with a thru the floor/ceiling register that would have heated the room above it for sure. You needed to leave the stairwell door open for return.
    I have seen a few very old what looked like passive vents above ranges.
    JUGHNE
    EdTheHeaterMan Member Posts: 12,203
    There's electric in that-thaire wall! See the knob holding the cloth insulated wire?
  • Intplm.
    Intplm. Member Posts: 3,021
    Back in the nineteen eighties, I went to fix a leak on a drain serving an entire bathroom group. Was the only bathroom in the house. Was a relatively nice place.
    Pulled the lathe and plaster down and found that type of old downspout pipe for their main drain!? The customer wasn't ready for the bad news of having to change everything from the second floor to the basement.
    When finishing up I asked the customer when the house was built. He said in the nineteen thirties.
    I thought, later on, the things people will do out of desperation. This had not leaked for over fifty years.
    This pipe was installed during the Depression and lasted all that time.
    The above picture brought me back. Wow.
  • ChrisJ
    ChrisJ Member Posts: 17,391
    Sounds better than Orangeberg, :)
    Intplm.
  • Intplm.
    @ChrisJ ....... Worked with that too. LOL.
    Can you believe that the depression era folks who installed that downspout had tied it into a large tin can used as the closet flange for the toilet?
    ChrisJ
  • ChrisJ
    I can't even imagine.....
