Burnham Indirect Water Heater ?
Iggy
Member Posts: 2
Does anyone have any thoughts on Burnham Indirect Water Heaters ? I read a several threads claiming negative experiences with Burnham products
What series are you looking at? The stone lined ones are very durable but very heavy. If you have compatible water stainless tanks from other manufacturers may make more sense.0
I've installed Many Alliances (the heavy bums) never an issue for me. Mad Dog 🐕0
Did you have alot of problems with the Independence Steamers? Mad Dog 🐕0
Lots of problems with the independence. Short lifespans. Lots of failures in 10-15 year range. Mostly see Burnham and Weil McLain. Talking about gas steamers. Residential. The WM easily have double the lifespan, in my findings
In the 1990s, we saw alot of WM Failures. I never saw the Independence problems in my area...but I have heard that. Mad Dog 🐕1
@Mad Dog_2. How old were the WMs they were failing? Was it the boiler itself or the connections? Push- nipples or elastomer?0
They were mostly the first generation of the Elastomeric section rings...whatever year they came out with the them..(early 80s??) I believe WM found it was Petroleum based additives that caused the leaks. WM stood by their brand which was noble. Personally, I'm not crazy about joining boiler sections WITHOUT the steel push nipples. You put Fire 🔥 Cast Iron and rubber together...Rubber loses. That being said, I've put in plenty of WMs (residential & commercial & Williamsons...VG boilers. Mad Dog 🐕0
I think ghat us a stone lined tank built by Vaughn. They last a long time, very heavy to move around
Used to be they had a finned copper coil. Those could scale up with hard water. Some had a removable coil and a hand hole to serviceBob "hot rod" Rohr
Living the hydronic dream0 -
I've had two contractors suggest the Burnham AL70SL
I'll locate the threads, I'll locate the comments and post them. It was in these forums. Thanks0 -
I remember when Vaughn first came out , then the Alliance came out . Thought it was the one of the same . I had a few heat exchangers fail under warranty . It would not be a problem to replace heat exchanger , yet Burnham gave us a new tank . I prefer an indirect with a bigger boiler supply . I am not a fan of stainless . They sound like a good idea , but I seen too many leak with poor welds .
1
