Nitrogen
Service experts. I have always wondered if the Nitrogen flows through the compressor when brazing it in. If nitrogen does flows through the compressor and how ? Does compressor internal discharge open let nitrogen flow through since only 1.5-2 psi ?
    pecmsg Posts: 7,551
    When brazing you only flow at extremely low pressure. (1 1/2#'s it way to high.) All your trying to do is displace any oxygen to prevent copper oxides from forming. ASSUMING something is open on the high side and there's NO control valves yes it just flows through the compressor from low to high sides.
    pecmsg Posts: 7,551
    Is this a school test question?
    I ask because you posted the same thing on H-talk.
    johnjohn89
  • ChrisJ
    ChrisJ Posts: 17,675
    You need a flow gauge......
  • johnjohn89
    johnjohn89 Posts: 115
    Haha
  • johnjohn89
    pecmsg said:
    When brazing you only flow at extremely low pressure. (1 1/2#'s it way to high.) All you’re trying to do is displace any oxygen to prevent copper oxides from forming. ASSUMING something is open on the high side and there's NO control valves yes it just flows through the compressor from low to high sides.
    But how?  compressor discharge allow to open since only flow through 2 psi nitrogen?
    and I try to find information about can nitrogen
    flow through compressor but I can’t find any, do u know where I can find info about that? Thanks
    pecmsg Posts: 7,551
    Discharge valves are like a check valve, As long as flowing from low side to high side.
    STEVEusaPA
  • ChrisJ
    edited April 2023
    Wouldn't a scroll block the path?
    Although it should be unloaded if not running...
    pecmsg Posts: 7,551
    Scrolls have a check valve to prevent back spinning.
    EBEBRATT-Ed Posts: 21,026
    There is no back pressure on the discharge valves since the compressor is not running they will open under little pressure.
