Installing heat pump system: Risky for my oil heating pipes to go under-utilized?
fiveightandten
Member Posts: 5
I'm installing central air in my house and the cost to upgrade to a heat pump system is only marginal and attractive from a heating cost standpoint.
What is the level of risk to the heating pipes feeding my oil-fired baseboard if I stopped using them as a primary means of heat? Is this even advisable? The HVAC contractors we're getting quotes from say it's fine, but I have some doubt.
Make sure you treat your heating oil tank with the proper additives, and try to get non-bio only if possible. The newer fuels just don't sit well like the ole high sulfur heating oil. There's a whole business of fuel polishing by generator companies who's customers have generators that don't run for years (except exercising) that have hundreds of gallons of fuel just sitting there.
Where are you located?
Some jurisdictions require the oil/gas system be removed before you get the rebates.
- 120 Geothermal
- 394 Solar
