replacement options for Armstrong H-54-1 pumps.
ratio
Got an old Armstrong pump that's leaking around the seals. What kind of replacement options do I have? In particular, is there an ECM pump that will go into the existing volute? How 'bout something that'll fit in between the existing flanges? (Are pumps this size pretty standard?)
I do have a spare bearing assy on hand, but I'd like to offer the customer some (an?) energy saving choices.
Thanks!
with the flange to flange dimension you should be able to find a cross reference at the various manufacturers sites
the Armstrong Compass looks to fit in that spec rangeBob "hot rod" Rohr
Living the hydronic dream1
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
