Electric Boiler Recommendations and Advice Needed
Prevch
Prevch Member Posts: 120
Has anyone every installed an electric boiler for in floor radiant heat? What was your experience like? Do you have any brands that you would recommend?
    EdTheHeaterMan Member Posts: 12,506
    edited March 2023
    There seems to be a trend to use Air to Water heat pumps for this. Since you do not need high temperatures for radiant floor heat and those heat pumps can get you 120° or greater water temperatures, they seem to be a great match. What size are you looking for, more or less than 50,000 BTUh?
    Mad Dog_2
    hot_rod Member Posts: 27,842
    What are your electric rates?
    Here are a couple of my favorites. Electro is US built, Thermo 2000 is Canadian
    https://electromn.com/electric-boiler/
  • Prevch
    Good question. Right now, I have a 200k BTU propane boiler that I absolutely hate and I want to get rid of it. That being said, I think it is way oversized for the house. I turn it down to 30% power and it still heats the house fine. I think I probably could get away with 50k BTU because all of our heat is in floor, but it really is just an experiment at this point. Have you ever heard of using a hot water heater to run the in floor heat? I'm wondering if I could get one of those hybrid electric models and just run off of that.
  • Prevch
    Awesome thank you I will look into those. Have you ever heard of running the in floor heat off of a hot water heater? I was looking at one of those hybrid electric models. If it would work, I could see the advantages of it for sure.
  • Dave Carpentier
    Dave Carpentier Member Posts: 640
    You should consider doing a heat loss calculation for the house. Guesstimating might work, but underestimating is obviously a problem, and overestimating wastes money. I used the SlantFin app (free at GooglePlay).
    Electric heating -- What are your plans during a power outage ?
    Ive toyed with the idea of electric boiler with a large storage tank and using time-of-day pricing to keep the electric bill reasonable.. but it keeps coming back to -- What to do during a power outage.
  • Robert_25
    Robert_25 Member Posts: 575
    Prevch said:
    What are your electric rates? Here are a couple of my favorites. Electro is US built, Thermo 2000 is Canadian https://electromn.com/electric-boiler/
    Water heaters are not made for that type of duty cycle, and likely would not have enough capacity to heat your house.
    Electric boilers work well, but are normally used only if the electric rates are very low.
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,243
    edited March 2023
    No, a heat pump hot water heater takes heat from indoors to heat the water so it would work out to be just resistance heating. Plus they’re too small for your load and aren’t made for central heating. Electric boiler for cheap install/expensive to operate or air to water heat pump for cheap to operate/expensive to install/option for cooling. You can always keep the propane boiler as backup.
    KNPV_PSD
    edited March 2023
    A common 4500w electric water heater, runs on a 30a 240v circuit gets you about 15,700 btu/ hr
    5500 w upgrade gets you 18,755 btu/hr
    So knowing the actual load is quite important.
    Run some operating costs here
    https://coalpail.com/fuel-comparison-calculator-home-heating
    pecmsg
  • Prevch
    We have two wood burning stoves that can heat our whole house in the event of a power outage. I mean, we are honestly in the same boat now with propane. If the power goes out, the boiler does not work.
  • Prevch
    They aren't low, but they aren't high either really. I am just done with gas/LP
  • Prevch
    I could, but it breaks every 5 minutes. I hate it so much.
  • Prevch
    Thank you
  • KNPV_PSD
    KNPV_PSD Member Posts: 3
    I just commissioned a Thermolec 18kw to heat my 40x60 shop in NW Montana. Financials worked for me because: a) no natural gas b) propane even when bought in summer varies from $2.19-2.49 c) we have very cheap hydro power at $.06/.07/.10 based on tiered usage. Cost was slightly cheaper for electric so for ease of installation and stabilized rates, I did electric.
    The unit itself is nicely built, has a simple outdoor reset, and just works. My main complaint is it makes an electrical hum non stop when not heating but I am a little sensitive to sounds I find annoying….
  • Prevch
    Thank you for that info
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,673
    One of the long time advertisers and friends  here, John Hazen White & Taco,  has a really nice Air-to-water  Model I can't wait to use. I'd check that out.  Mad Dog 🐕
    Thermolec, Electro MN, and Thermo 2000 all have nice electric boiler options.
  • Prevch
    Thank you!
  • Prevch
    Thank you!
