Has anyone used Lochinvar's Wireless Outdoor Sensor, or similar?
JohnNY
Member Posts: 3,393
Does it work? Any idea of the range it's capable of in real world conditions?
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
Hangin' in the wind, eh Johnny? I wish I knew. BUMP! (in the hopes someone will see this) Mad Dog1
Seen it & am interested in the replies as well, but don't have any data to supply. Best I can do is add to the post count & hope someone with the answers sees it.0
I have used the Tekmar wireless one about a dozen times with good success. I think the range is up to 200’.2
Better off with indoor reset.John Cockerill Exquisite Heat www.exqheat.com Precisions boiler control from indoor reset.0
Thanks a lot. I ordered one from Lochinvar and it's an HBX product saying Lochinvar nowhere on the box, oddly. I'm going to try it out. The system runs mostly at 170° setpoint anyway.EzzyT said:I have used the Tekmar wireless one about a dozen times with good success. I think the range is up to 200’.
Classes0 -
This one: https://hbxcontrols.com/wav-0110.php ? It claims up to five receivers for one outdoor transmitter, I think that might be the only way to get several different pieces of equipment to display the same temperature.0
I installed it today. Doesn't work. I have to go through it tomorrow with HBX. It stops reporting the moment we leave the boiler room with the outdoor unit.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes1 -
I believe that the tekmar wireless is not constant signal , that it intermittency sends a signal every few minutes from the outdoor sensor which I would image effects the boiler main board by intermittently showing connections and then zippo . Showing a signal one moment and none later . I would hope would have some information about this and any effects it would have on most mod con boards . I doubt there’s any issue when using tekmar odr controller w there wireless sensor but I would think if there was a bug on using w other manafactures that they would have ironed it out being it’s been available for some time now . Have you checked the wirelesses dip switches to ensure it set up for then resistance that the manufactures is using . 10 k 12 k you know . Worse comes to worse it’s a call to tech service and hear there wisdom
Peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating1 -
- 128 Chimneys & Flues
