Oatey Flanges
taylorgeo
Member Posts: 74
Apology for starting a new thread on flanges, but I just wanted to get more specific.
Just curious why these two flanges have gaskets that expand to make such a tight seal? If end up having a viable lead or cast iron pipe, why couldn’t I just pop in a flange without a gasket?
Thanks in advance.
Thanks in advance.
If a WC flush hesitates going down to the main sewer, water could back up and seep at that point.
It is better to have the bowl overflow than have a leak under the floor that you may never see.....but eventually smell.
The bowl wax would be a weak point and might get blown out but this is something you would see and easily fix.0 -
I think I found the pipe going up to the second floor toilet.
Can anyone tell me if it's Cast Iron or Lead? House was built in 1945.
Here's a photo...
Magnet will stick to cast.
Lead may have been used to transition to the floor flange.
Soft, almost scratch it with a fingernail.0 -
cast iron or lead unless it was replaced in which case it could be pvc or it could be cast iron with repair pieces attached0
In the plumbing trade...you have to be able to join anything to ANYTHING.0
I doubt if the pipe goes straight up to the flange without a bend.
A straight 8' drop out of a WC flange might cause problems.
IDB there is always a bend......code??? Someone here knows for sure.0 -
It would have to be vented near the bowl somehow so it would pull in air from the vent rater than the bowl. That is usually a tee(or tee wye, I'd have to look at the code) that continues up the vent with the bowl connected to the branch.JUGHNE said:I doubt if the pipe goes straight up to the flange without a bend.
Thanks in advance.
Those are retrofit flanges, used when you cannot or don’t want to attach to the outside of the pipe.
They should fit or be available for PVC, and ABS, possible the hewed no-hub cast iron pipe.
Obviously the inside of the pipe needs to be clean and smooth for a proper seal
Living the hydronic dream0 -
I use my best screwdriver usually
I'm really curious how you get a nice clean smooth surface for that rubber to seal against on cast iron.
I'd expect the only realistic place for that to work is pvc or abs.
I have seen a lot of old installs here, done in the 50's perhaps, where 4" cast is run close to the floor hole.
Then a 4" lead bend is used to go up thru the floor.
Or a CI 90 is used for the bend and a lead riser up to the floor. Sometimes see some creative offsets done.
The lead was extended up maybe an inch or so. Then the lead hammered over down flat on the floor to develop a flange.
Bowl wax used and lag screws into the wood floor secured the WC (for quite a few years anyway....then maybe longer larger lag bolts used....most WC's had 4 floor mounting holes....all used most of the time.
So 50 years later with rotten wood, time to repair. New wood as needed, bend up the lead flange and hammer back down on the new wood.
I have used the top pictured flange on lead, the lead is soft enough to conform with the rubber gasket.
IIRC it even worked sometimes on CI.
There is a potential surprise under every WC.
Taylorgeo, the wax will only seal between the china and the flange.
You need a tight seal between any new flange and old.
You may have a CI flange under the WC.
There are several to repair that simply if needed.
Show us what you have.0 -
There are rubber seal type that clamp on the outside also. You just need to see what you uncover, then buy the best flange. There is a good chance you can reuse what you have now. Could be just a failed bowl seal.
If the wood did get wet, you need to get it dry before resetting, else you get a mold growth, smell, etc.Bob "hot rod" Rohr
If you wanted be prepared before pulling the WC;
Assuming you have a CI flange, sitting on the finish floor, that may be rusted and not hold the bolts, I would get the flange repair ring. It is flat steel that might hinge open to install and provide new mounting slots for bolts.
If you have a flange that is flush with the finished floor then get 1 or 2 PVC flange extenders.
They are sealed to the existing flange with silicone caulk and screwed into the floor. This puts the flange just the thickness of the flange above the floor. Usually needs only 1.
And get the flange shown in your first picture just in case.
Also a standard no seep wax and then an extra thick wax.
Bowl bolts as needed, I like the 5/16" size.
Maybe a SS flex supply connector.
Some 2" x 10 screws to drive into the floor.
You can buy all of this in advance and return what you do not need.
I would guess a plumber would have all of this in his truck and more.0 -
Under the NSPC, the maximum length for a trap arm for a water closet is 3' vertically, and 9' horizontally.0
Thanks, everyone. I purchased everything except for the screws that would attach the flange to the subfloor. I think it's wood under the tiles. Can you tell me exactly what screws to get?
I'll gladly buy a variety of screws for different subfloor materials JUST in case it's NOT wood under the finished floor.0 -
It is probably a variety of lengths of screws that you will need. You won't know that until you know how thick the layers between the flange or extension or repair flange and the wood is. There is a strong possibility they raised the floor and never extended the flange and the bowl ring just failed because the flange is too low.2
I swear, last question: If it is cast iron underneath the toilet, is it more likely to be 3 inches or 4 inches here in New York City?0
Older stuff tended to be 4".0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
