Old Water Heater or Gravity Fed Hydronic?
SENorthEast1895er
SENorthEast1895er Member Posts: 100
edited January 2023 in THE MAIN WALL
This is in my attic and i’m wondering if it’s an old water heater (where they ever put in attics?) or a remnant from when my system was switched away from gravity fed.
    hot_rod Member Posts: 28,250
    with a site glass it would more then likely be an expansion vessel.
  • SENorthEast1895er
    Interesting. Why in the attic? Trying to figure out if I used to be gravity-fed.
    The highest place in the system, it added the pressure to the system and served as the expansion "space"
    mattmia2 Member Posts: 18,044
    The system was open to the atmosphere at that tank. If it was lower in the system the water would come out.
