Prestige triangle 110
failedheater
Member Posts: 1
No heat since saturday, the triangle tube supply/return sensor failed, is there a way to bypass until the new sensor comes in
No, if the control board doesn’t see a value that’s right it will lock out.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 128 Chimneys & Flues
