Ice in a container
Does ice keep expanding as it get colder, or does it reach a point at ? deg and remains the same demenstions? I have a water tank that I didn't get emptied before this hard freeze. I've broken the ice on top and scooped it out along with most of the water. But, there is 6" thick ice on the sides, and I don't want the ice to buckle the sides the bottom might have an inch or so, I don't think that will hurt the bottom but, I'm not sure. Any answers would be kindly appreciated Thank,s and Everyone have a great Christmas Day and a Happy and prosper New Year.
    hot_rod Member Posts: 28,242
    Dump some salt in it
  • HomerJSmith
    HomerJSmith Member Posts: 2,812
    It can only expand so far. Ice like water expands in the direction of least resistance.
    Jamie Hall Member Posts: 27,749
    If you've taken the still liquid water out, you should be OK. No guarantee -- but should be.
    A more complete answer to the question -- water has its maximum density at 4 Celsius, and gets less dense (expands) both below and above that. Ice has significantly less density that liquid water at any temperature (why an iceberg floats!) but has its maximum density at freezing.
  • SlowYourRoll
    SlowYourRoll Member Posts: 187
    edited December 2022
    ice actually gets more dense the colder it gets. once the H2O molecules lock into their lattice as a solid, their intermolecular spacing is basically just a function of heat, with higher temps being more energy and greater intermolecular actions against each other. you know how everything "stops" at absolute zero? that also means zero intermolecular force, hence greatest density.
    https://www.engineeringtoolbox.com/ice-thermal-properties-d_576.html
