Rinnai 120CN not reaching temp setting
cfar
cfar Member Posts: 13
I have a Rinnai 120CN combi boiler which won't hit the desired boiler temp.
I'm using room air, natural gas and with a single zone layout.
I current have the DHW temp set to 120* which works perfectly.
However, the boiler is set at 165*, but it will only get to 143* and then "cycle" back down to 130* and then do it all over again. Ive played qith temp settings  but I can't get the boiler to reach anywhere close to its target. And as you can imagine,  this is not optimal with the current weather situation most of are experiencing.
Thank you.
  • cfar
    Once it gets to ~140* the fuel seems to run out and begins to sputter.
    I played with the settings giving the boiler portion priority.  It's been hovering around 130* for a couple hours now.
    Jamie Hall Member Posts: 27,584
    You may have a gas pressure problem -- but that takes specialized training to check. It wouldn't be surprising, since everybody and their uncle is using gas on days like this.
