We are McLennan boiler only goes up to 140°
criv
criv Member Posts: 1
What do you think the problem could be on my wheel McLean boiler it only goes up to 140° even though I have the digital control board set for 200
    hot_rod Member Posts: 27,845
    Is the ODR outdoor reset function enabled? That limits temperature based on outdoor temperature.
    HVACNUT Member Posts: 7,526
    edited December 2022
    What digital control board? If it's the Hydrostat 3250 Plus, then check to see if the jumper B is installed. If it is, remove it. Then turn the High limit down to 160°. But given almost zero information,  thats just a stab in the dark.
  • kcopp
    kcopp Member Posts: 4,700
    Tell us more about your system please. What type of radiators? Baseboards? cast iron?
    EdTheHeaterMan Member Posts: 12,506
    Does your WHEEL McLennan boiler actual have wheels, are you sure it is not a McLaren with Wheels like a Formula 1, or maybe an IndyCar, or perhaps an Extreme E car?
    If However you have one of the newer Weil-McLain boilers that is using a modulating control system and has outdoor sensing, the boiler may not get to 200° ever... unless you have it connected to an indirect water heater.
    ethicalpaul Member Posts: 8,930
    Not everyone is able to see or type so they use voice transcription which is a great help to them, so let’s have some grace about it I humbly suggest
  • ScottSecor
    ScottSecor Member Posts: 1,042
    Post a photo of your boiler and we may be able to help.  Take one from about two feet away and a second photo from about ten feet away
