Float vent for an old steam system
Hi,
We're having a hard time finding a replacement for this old Trane and Co float vent installed at the end of the line on a steam system.
It's a Trane and Co. Float Vent model number 1010-1.
Saw a post about this recently but wasn't able to find it again today.
Any suggestions are appreciated. Thank you.
    A vent is, pretty much, a vent. Which means that you can replace it with a modern vent -- such as a Gorton #2. In that location you may have to get a bit creative with a couple of nipples and elbows to get it on.
    BradandTimshow
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,843
    Are you sure it's not working?
    BradandTimshow
  • bburd
    bburd Member Posts: 1,318
    A Gorton #2 is pretty big, might need something shorter in that location.
    Bburd
    BradandTimshow
    EBEBRATT-Ed Member Posts: 20,485
    You can also build a header and use multiple smaller vents if a big one won't fit
    BradandTimshow
  • BradandTimshow
    BradandTimshow Member Posts: 2
    Thanks for your replies. That gives me some things to consider. I'm brand new to steam heat.
    Appreciate it.
