Peerless Purefire PF80 A01 fault "no spark"
John_001
John_001 Member Posts: 4
My Peerless Purefire pf80 has lockout code A01.... the unit was installed 4 months ago and has work flawless till today. The installer came out and says there is "no spark" and the control board needs to be replaced.
Installer checked and clean the igniter and inspected igniter lead, says there are ok but when he grounded the igniter and "call for heat" NO spark... tells me to call Peerless Boilers to get a warranty on the board and he'll install... Is there a tech line I can call for Peerless??
Is there any other way to verify this is the problem??
Any help would be appreciated
Thanks John
  • Ironman
    Ironman Member Posts: 7,927
    The installer tells you to get the part under warranty? That’s his job - unless you purchased the boiler and paid him to install it.
    Bob Boan
  • John_001
    I still have a tough time believing the control board is bad already
  • John_001
    well it turned out to be the control board.... got heat now!!
