Burnham Boiler help please!
bgoldsau
Hi, our Burnham Boiler is leaking just a little bit (water with sediment). Please see the photos as I’m not sure what you call the part that it’s leaking from or what the problem is. I’ve read some other posts on here and am confident and grateful that someone will be able to help me. Thank you!
Hi, our Burnham Boiler is leaking just a little bit (water with sediment). Please see the photos as I’m not sure what you call the part that it’s leaking from or what the problem is. I’ve read some other posts on here and am confident and grateful that someone will be able to help me. Thank you! 0 -
It's a ¾" hose spigot. Also called a boiler drain. It's no big deal.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes3 -
A kleenex piece of toiler paper is a good way to locate a seeping connection.
I'd suspect that ball valve packing, since the handle is rusty, or a pump flange. Sometimes the drip only happens when the system is cold, parts contract.Bob "hot rod" Rohr
Living the hydronic dream0 -
new hose cap and gasket. most hardware stores and big box stores will have them0
I've merged these duplicate posts into one here. Thanks!
President
HeatingHelp.com0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
