Laars Indirect water heater
bpkiely
Member Posts: 5
Has anyone installed a Laars single wall indirect water heaters and are they a good unit? I can save $200 bucks over Superstor plus I like the top domestic water tapping. easier to install mixing valve. They also include aquastat and t&p valve which I do not think the Superstor does. It is on city water.
Digging deep, you may find 2 or 3 manufacturers make the steel tanks and they just put different labels on them. Longevity has to do with operating temperature, water quality, and how much water pass through them.
With steel tanks, checking anode rods is a good idea to get maximum life.
As for stainless tanks, look at the manufacturers water spec. If your water does not meet the spec, officially you have no warranty. Snoop online for the data sheets on the models you are considering for water quality spec.Bob "hot rod" Rohr
Living the hydronic dream1
- 125 Chimneys & Flues
