High Head Lockout vs Crankcase heaters
who would like to give me a 50 cent tour and explain how failed crankcase heater leads me to High pressure lockouts,
my brain tells me the refigerant is carrying the oil out with it(duh) and that the oil is not compressible in the system, voila, high press trips,
am I close?
known to beat dead horses
    pecmsg Member Posts: 7,378
    The crank case heater is to keep the oil warm and prevent refrigerant from migrating and condensing in the compressor sump. If the heaters bad not operating then you can
    pump out excessive oil
    operate with out proper lubrication
    AKA kill the pump.
    NO relation to excessive head pressure
