Wiring for Taco 501 w/Primary and Secondary pump
Can anyone give guidance on how to wire both primary and secondary pumps, 1/6 HP Grundfos pumps, to a SR501 switching relay. I have a single zone and want both the primary and secondary to turn on at the same time. Do I pig-tail the connections into one entry in the relay? Or will that blow the 6 amp fuse it the switching relay? Any guidance is appreciated
  • pedmec
    pedmec Member Posts: 1,446
    What model boiler? That's all i'm gonna ask.
    @EdTheHeaterMan Take it away. You have all the beautiful colored diagrams.
  • mhausmann
    mhausmann Member Posts: 3
    Eco smart ECO 27. Motion activated.
  • JohnNY
    JohnNY Member Posts: 3,380
    Join them at the 120v pump terminals. Unless you experience a locked rotor or something, it'll handle the draw. I've done it many times, though I hate to admit it since there's really no good application for having two pumps tied to each other on separate loops.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • GroundUp
    GroundUp Member Posts: 2,525
    That's not a boiler, by the way. Make sure you get a fire suppression system in that room, there's a good chance you'll need it. The circs you're talking about, likely 26-99s, would only draw 3.6A combined. They'll be fine with the SR501.
    EdTheHeaterMan Member Posts: 12,444
    Is this what you were thinking of @pedmec?
  • pedmec
    Absolutely. I mean, You just cant get it any clearer than that.
    Is that CAD software your using? I hope you don't mind me asking
    hot_rod Member Posts: 27,705
    Its a tankless electric water heater. It will need a highead circ no doubt, 26-99 as @GroundUp mentioned, a smaller one probably for the system.
    That is probably a 5 amp relay in the 501, just wire them onto the same terminal.
    STEVEusaPA
    edited October 2022
    You are not the first to ask. But I don't have that technical stuff. I used to use a program called PAINTBRUSH when I had a Windows computer. Now with a MAC it is called Paint.
    I don't even know how to use PhotoShop.
  • pedmec
    Well whatever your doing its pretty good. I like it. Better than the hand written messy drawings i slap together
