Prestige boiler issue
I have like-warm water to all faucets in my home. All discharge pipes from boiler are almost too hot to touch. Heat in house works just fine. I’m at a loss as to why this is happening. HELP!
    EBEBRATT-Ed Member Posts: 20,476
    dhw heat exchanger may need internal cleaning with chemicals. did this happen gradually or all of a sudden?
  • psb75
    psb75 Member Posts: 1,154
    Is there a bad mixing/anti-scald valve on the system?
    kcopp
  • tim smith
    tim smith Member Posts: 2,935
    Bad pump for indirect hw tank?
  • bburd
    bburd Member Posts: 1,318
    This can happen when a mixing faucet, like a shower valve, is left open and the flow stopped with another valve downstream, such as a handheld showerhead.
    Bburd
  • Do you have a Prestige Solo (heating only with a sidearm water heater) or Prestige Excellence (combi)?
  • Zman
    Zman Member Posts: 7,614
    My bet is a cross connect between hot and cold. What changed? Did you add a shower head with a shutoff somewhere?
    Albert Einstein
