Main steam air valve or hydronic heat air valve ?
This is the main air valve on my steam boiler is this correct? The air is venting through this tiny valve but it looks like the wrong one.
    mattmia2 Member Posts: 17,478
    No. Those are marketed as steam or hot water automatic vents but they really are not good at either. That should be replaced with one or more steam main vents.
    S_olanooptical1
    Jamie Hall Member Posts: 27,584
    Poor little thing. Wrong valve, may well be in the wrong place. How is that connected to the steam main piping?
  • S_olanooptical1
    S_olanooptical1 Member Posts: 2
    It is connected to the vértice return pipe. Also, Should I move it away from the elbow with a vértice nipple?
