Combustion Analyzer
Hey fellas:
I'm currently using a Bacharach 0024 analyzer that does everything I need; CO2, CO, O2 and efficiency. It's about 12 years old and I'd like to have another one in case this one dies and am in the market for one with equal diagnostics.
I've heard good things about the Testo 300, but it's $1,400 without a printer. (Is it really worth it?). I'd like to get something good under a grand. I might just end up with another Bacharach if I can't find one of better quality as it's been fine all these years.
I've been using the Testo 300LL for a few years now and I can't say enough good things about it. I had a Testo 320 and I always thought it was good enough but the 300LL is so much nicer to use. The long life sensors are definitely worth it in my opinion.
I see Fieldpiece finally started selling a real combustion analyzer, it might be worth giving a try if you aren't going with the Testo or Bacharach.1 -
EUi is a nice instrument. I could send my kid to college for what it cost me to calibrate it every year.0
I purchased the TPI 610 Combustion Gas Analyzer last year and have found it very easy to use. The unit does not have a display but connects to your smart phone via Bluetooth.Very easy to generate and email reports I bought from TruTech tool (link above), the price was $405 before tax. The unit arrived in a couple days with a new calibration cert. The TPI 610 has user replaceable CO2 and CO sensors; the sensor are warrantied for two year. I talked with a TPI tech re calibration and sensor replacement; calibration alone is around $60; calibration with new sensors is approx. $200. He said the sensors are user replaceable but typically people send the entire unit back so it can be recalibrated at same time.1
I see that Amazon has a Testo 300 "Used - Like New" for about $600 less than brand new. Perhaps purchased and then returned soon after.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Can you add the warranty for a few bucks more?I'm hoping to get the full warranty included.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
never had any issues with Amazon handling warranty. We been shipping “prime” for 15 years or moreBob "hot rod" Rohr
Living the hydronic dream0 -
I have two testo 320s costing about $250 each per year on maintenance
We had a backarack Ensign With the O2 sensor program which was great you Could change your own sensors, but that died.
Looking into something new looking for some advice thanks0 -
The school of hard knocks???STEVEusaPA said:What college is that?
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
