embed pex in slab or pourover?
baltik
Member Posts: 21
In my new addition I have 8" of structural floor depth to play with. The engineer specd 6" slab leaving me 2".
So essentially i can do:
2" insulation then 6" slab with embedded pex
OR
No insulation, 6" slab, thermal break then 2" gypcrete.
I am leaning towards option 2 since the area I live in is cool but mild (never below freezing) and I like the idea of having a responsive system where I can turn down a few degrees at night. However gas is also very expensive where I live, so my primary concern is overall efficiency. What's the better setup for my use case and are there other factors I'm forgetting?
OR
Add 2" fill, compact, 2" insulation and 4" slab, tube suspended 2" below top.
Really no need for 6" unless you plan on working on heavy equipment in there
Spray foam is becoming the norm around here for underslab, gets you a perfect vapor barrier from Radon concerns, etc.Bob "hot rod" Rohr
Living the hydronic dream0 -
I need the 6” for structural reinforcement of existing foundation….0
somehow, somewhere you want a 2” minimum insulation layer. Anything less will just increase the downward heat loss and operating costs over the life of the system. That 6” slab will be a large, conductive heat sink. At some point as that mass warms it would be hard to control over heating potential.
Any or the radiant simulation programs would show the loss and related costs associated with insulation thickness options.Bob "hot rod" Rohr
Living the hydronic dream2
- 129 Chimneys & Flues
