Question Taco 007-f4
rick1957
Member Posts: 1
Hello how long do these last new in the box? Meaning if I can use a $20 off coupon to buy one now, will it be ok years from now if I need it. Thanks
I have had those pumps on service trucks that sat idle for 2 years (spare service truck for technician when their truck is in the shop) and that pump will be 3 years out of warranty. I still use them and the work without a problem. Old stock when it comes to motors, keep in a dry place above 45° and below 90° and you will have no problem. If you put it in the attic and the roof leaks on the box and then it freezes, then it gets to 120° next summer, then gets wet again the following winter. It will probably still work but there is a chance for failure under those conditions.
I would buy it.Edward Young Retired
1 -
You want to sit on one for who knows how long, to save $20? For starters there are more efficient ones on the market. And by the time you need it there will probably be a better one.
Search around on the internet for the best price and see if you are getting a good deal. The price will certainly increase and you may not need anything better than that. The cost to repair a pump is almost the price of a new pump.0
