Code e3-01 on Daikin VRF unit
Having an issue with a Daikin VRF unit model# RXYQ120PBTJ. There is no operation from the unit, and the indoor thermostat is displaying an error code of E3-01. I am getting conflicting information that this could either be a high pressure condition, or an electrically shorted compressor, or fan motor. I reset the high pressure code through the push buttons in the outdoor unit, the code went away on the thermostat, and then when I went to turn the thermostat back on the code immediately came back on. The unit made no attempt to start. I would think that it was a high pressure condition, that the unit would have ran until it reached the cut out pressure. I know these VRF units are very unit specific, I was just posting to see if anyone else had had a similar issue with the same unit. thanks to all
  • Ironman
    Ironman Member Posts: 7,927
    A shorted compressor can easily be confirmed or eliminated with a meter.
    I agree that it’s unlikely a HP lock out if the system has had enough time to equalize.
    If you eliminate both of those possibilities, it might be time to call tech support.
    Bob Boan
    zepfan
  • zepfan
    zepfan Member Posts: 467
    It turned out to be the inverter compressor was grounded. I went back today with a megger, and didnt need it because the compressor was grounded so bad a standard meter could pick it up. Strange that the same code could be a refrigerant, or electric issue
    Ironman
