Piston
Why charge wet bulb and dry bulb when system use piston metering device ? And why txv doesn’t charge by wet bulb and dry bulb ?
  • ChrisJ
    ChrisJ Member Posts: 17,545
    edited May 2022
    As far as I know with a fixed orifice device like a piston you charge by superheat.
    With a txv you charge by subcooling because the txv controls superheat, so you can't really charge by it.   Personally I watch superheat as well with a txv and adjust the txv if possible to get both superheat and subcooling where they need to be .
    Subcooling is really just showing you how much reserve liquid refrigerant you have backed up in the condenser.
  • pedmec
    pedmec Member Posts: 1,473
    because with fixed metering device a greater portion of the refrigerant is used to remove the latent heat plus the sensible heat. so on a humid day your superheat will increase due to the higher latent heat load on the evaporator coil.
    with a txv it will just open up to maintain the proper superheat due to the increased load.
  • johnjohn89
    johnjohn89 Member Posts: 115
    Ture thanks
  • johnjohn89
    pedmec said:
    because with fixed metering device a greater portion of the refrigerant is used to remove the latent heat plus the sensible heat. so on a humid day your superheat will increase due to the higher latent heat load on the evaporator coil. with a txv it will just open up to maintain the proper superheat due to the increased load.
    Great answer thank u so much
