What should I expect out of this boiler?
DudeAbides
DudeAbides Member Posts: 9
So I bought a duplex recently which came with this boiler installed in the basement:
https://winsupplyinc.com/new-yorker/_/A-01152832
The upstairs is entirely electric, so the boiler is only responsible for the heating and hot water on the first floor. Unfortunately, it can only keep a hot shower going for about 3-5 minutes before dropping into the low 90s/high 80s f... definitely not a satisfying bathing experience.
So, before I add a supplemental tank to the system, I was wondering if I should expect this boiler to be able to supply enough hot water for a 15 minute shower? Is it potentially just in need of a service to restore it's capacity?
thanks!
  • DudeAbides
    Flat out that boiler might -- might -- give you about 2 gpm of 110 degree water. So if you are using a low flow shower head, and the boiler has been recently cleaned and adjusted, maybe.
    DudeAbidesMikeAmann
  • DudeAbides
    Alrighty then it looks like a tank it is. thanks!
    EBEBRATT-Ed Member Posts: 20,482
    @DudeAbides
    Tankless heaters for domestic hot water are not the best, but in a two-person home they will do the job if everything is set up properly. The boiler controls need to be set properly and if the mixing valve on the tankless coil is working properly.
    MikeAmann
  • DJD775
    DJD775 Member Posts: 259
    I've had similar setups before and they are adequate when the coils are totally clean but under perform if the interior wall of the coil becomes fouled up. Swapped to indirect tanks on both occasions and never thought about it again.
    MikeAmann
