WM ultra 155 circulator pump runs constantly
Rikster66
Member Posts: 1
I installed a WM Ultra 155 in 2008. It's been mostly trouble free. Yesterday I noticed that my main house heat circulator (circulator 3) was running with the boiler in standby mode. Are there any relays inside or behind the control module that may be stuck or is it time for a new control module?
I had a leak last year on the circulator flange that leaked down and ruined the display and blower motor. but everything has been running fine ever since.
Could be a bad thermostat. Could be a shorted wire. Could be a bad external relay...
I dont think it has to do w/ the boiler.0 -
If you remove the wires from 1 and 2 does the circ turn off?
Albert Einstein0 -
Form your question I assume it is zoned by circulators and not zone valves? What controls the circulators? Is there a zone control panel?0
