Suntec A2VA-7116 oil pumps discontinued by MFR.
MikeAmann
Member Posts: 422
in Oil Heating
https://www.supplyhouse.com/Suntec-A2VA-7116-Single-Stage-Oil-Pump-3450-RPM-9932000-p
The replacement is now the bio fuel version.
This model is specially engineered for B20 use (Viton O-rings and lip seal, special materials for piston and diaphragm valve).
Does anyone know why?
I’d guess every jurisdiction is moving to bio so it makes sense to make everything bio rated. Why make 2?
Same for filter and pump strainer gaskets and rings.steve0 -
Sort like what happened with ethanol in gasoline. It makes no sense to manufacture something which will not tolerate biofuel, since anything which will tolerate biofuel will perform equally well (or, often, better) on regular fuel oil as well.Br. Jamie, osb
That's what I was thinking. Thanks guys.0
- 117.6K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 403 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 680 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
