No heat
Changed a zone valve then boiler won't fire unless tester arcs across to anything metal
wmgeorge
  • STEVEusaPA
    Time to call competent pro.
    MaxMercy
    Jamie Hall Member Posts: 27,582
    This ^^^. Something is miswired -- but if a tester arcing across to metal is the way you are searchng for the problem, you stand a good chance of doing terminal damage to some very expensive electronics.
    MaxMercyHomerJSmith
  • HomerJSmith
    HomerJSmith Member Posts: 2,794
    edited March 2022
    A change from what kind of valve to what kind? I don't know what you mean. A little more information, forthcoming? A pic of your valve wiring, please.
    rick in Alaska
