Master Venting for One-Pipe Pumped Return (no main vents, only steam traps)
mgeraci
Member Posts: 13
Hello! I have a large building with a one-pipe steam with a pumped return. The building is interested in master venting, and when I surveyed the piping, I found there were no existing main vents, only steam traps at the ends of the mains before the condensate pumps. Would it make sense to do master venting on the mains here or is it unnecessary because the steam traps are venting the air sufficiently.
F&T traps, I presume? They do vent, after a fashion, but they aren't really meant to be vents. They're meant to be traps. It's likely that main vents -- on the mains -- will help. Be generous.Br. Jamie, osb
Yes, F&T traps. It's my understanding that the F&T traps are venting the air through the mains in the basement and the risers are vented through radiators and riser vents. Thank you for your input!0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 117 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
