Spout Reach
taylorgeo
taylorgeo Member Posts: 74
So I'm putting in a new drop-in stainless steel kitchen sink and faucet, most likely a pull-down. The inside of the sink measures 16 inches from back to front.
What size spout reach should I shoot for?
    Jamie Hall Member Posts: 27,050
    edited March 2022
    That's sort of a "how big is a box" question. You want the spout -- housed -- to be well over the sink, but with enough room for the chef's pots to fit in without too much trouble. But you want it to be able, pulled out, to at least spray the far corners. Couldn't possibly give you a hard number.
  • delcrossv
    delcrossv Member Posts: 2,189
    Usually I shoot for the spout to be directly over the drain as a nominal measurement. So in your case 8 inches plus your backset to where the faucet is on the apron of the sink.
    Larry Weingarten
    mattmia2 Member Posts: 16,093
    I guess you like water being deflected back up in your face...
    hot_rod Member Posts: 27,116
    With a pull down faucet it really isn't that big of a deal. I'm not sure they come in different reach lengths
  • ChrisJ
    ChrisJ Member Posts: 17,170
    My kitchen sink drains are near the back center. I never considered them to be meaningful when choosing a faucet.
    I would go for what looks and feels right to you. I hate it when faucets don't have enough reach so to me, anything that gets it more into the working area of the sink is better.
    But, maybe you won't like how that looks, or it won't be practical to your use.
    The pull out helps you reach all the corners as @hot_rod said. You want to make sure it is far enough from the back of the sink so you aren't hitting your hands on the sink when washing them.
  • ChrisJ
    I hate bathroom sinks with faucets like that.
    I've never understood why it's even a problem that exists. They know where the faucet is going, how is it only an inch from the back of the sink!?!?
    I used some high neck bar faucets on our lavs at the last house. Easy to wash hands under and they swivel.
    ChrisJ
    edited March 2022
    The distance the holes are from the back of the sink varies with different sinks so you need to coordinate and no one involved in commercial work is paying attention to that. Sometimes someone will care about how it looks, but never if it is functional. In residential work it is the same plumbers that can't follow the boiler piping diagram or homeowners that won't return something or bought from someone that won't take returns.
  • delcrossv
    edited March 2022
    I've never had that problem. Straight shot down the drain. If it's less than the drain distance then it splashes out.
  • ChrisJ
    I've seen some strainers that will do as he's saying.....
    What's even more fun is when there's a random spoon that for some odd reason is at the perfect angle to piss me off.
  • delcrossv
    The spoon will do it every time. 👍
