Tankless Water Heater Keeps Shutting Off
AdamAlvin09
Member Posts: 2
Hello Experts,
I just go a tankless water heater installed my home and it is from the Rheem brand. Everything was working perfect but sometimes it keeps shutting off automatically. Anyone can guide if this is normal or there is any problem that needs to be fixed?
Cheers!
Cheers!
There usually is a minimum flow below which they will shut off. Could that be it?Br. Jamie, osb
Depending upon the mode setting, cycling on and off could be normal. Please describe the symptoms in detail. Is it not producing hot water?0
inlet screen clogged?known to beat dead horses0
