Dunkirk quantum 90 not staying lit
wilson95
wilson95 Member Posts: 5
I have a dunkirk quantum 90 it runs through the cycle fine then when it get to light only lights for one second then shuts off and starts the cycle over I installed a new Igniter and air flow switch I and get it to stay lit only if I put a jumper wire on the air flow switch
    HVACNUT Member Posts: 7,175
    Check for obstruction in the exhaust and intake.
    Check for condensate blockage.
    Could be a plugged HX. Then you'll need a pro.
    Ironman
