Radiator Pitch
bobbob
Member Posts: 70
How much radiator pitch? 1/8th inch in 24" run? More? Less?
I wondered of too much pitch could cause condensate too drain too fast and cause interference with incoming steam flow
I'd like to see a bit more -- but not much more. If everything is piped correctly, there shouldn't be a problem. The amount of condensate is remarkably small, really, so if it can drain freely at all it should work.Br. Jamie, osb
@bobbob
There is no limit to the pitch. If you put a level on the radiator pitch it until the bubble is touching the line or 1/8"/foot0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
