Difference between a $14 and $80 vacuum relief valve?
Jells
Member Posts: 630
I'm baffled. Setting up a DWH and on Supplyhouse in the 1st 3 hits I see there's 3/4 valves from an $80 Zurn to a $45 Watts down to a $13.50 Cash-Acme. That's quite a variation for what should be doing the same job. What's up with that, what am I missing? It can't be the Zurn is so much better, I had one go bad on another tank.
Think about which valves are repairable. Which valves do not change the body types so repair parts are always available for that size and model valve, In that context the more expensive valve may be the cheapest.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron2
- 119 Chimneys & Flues
- 114 Geothermal
- 76 Pipe Deterioration
