Boiler water PH
It seems unusual that your boiler water would test that basic. (High pH). First thought is that something is wrong in the testing.If it is a pH of 14, which could happen, by seriously dosing the boiler with a lot of potent base, you could drain it, wash it out and refill.
If it is indeed pH of 14, be careful. Very caustic. The eye is especially vulnerable to base (high pH) splashes. Not good for skin either.Old chemist, not a heating pro.
best wishes1 -
To my knowledge there is nothing in the function of a steam system that will raise the PH like that. In fact the condensate returning will typically have a low PH <7. I use treatment to get my boiler water to ~10-11, but the wet return measures around 5.5.
Getting up to 12-14 is either massive amounts of water treatment or a faulty test strip.
How is the boiler working? I would expect a lot of surging at that PH level.1 -
That’s exactly what I thought as well. I am using a professional grade ph strips that I purchased from a reputable company. However, they could be bad…
I will order some different strips to see if that makes any difference
my water is foaming very bad… in fact, all the way up the sight glass0 -
Curious,erussell58 said:This may be a question more suited to a chemist than anything but here goes…
My boiler feed water is approximately 8.5-9.5 PH. However, when I test the actual boiler water, I get a reading of 13-14. Any guess what may be going on?
What's your boiler water's TDS vs the feedwater TDS?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I share KC's thoughts above except for the one about the surging at high PH. My video experiments showed me that high PH (which I achieved via Rectorseal 8-way) had no effect on surging, at least with my new boiler. I had cranked my ph to 13-14 without any surging.KC_Jones said:To my knowledge there is nothing in the function of a steam system that will raise the PH like that. In fact the condensate returning will typically have a low PH <7. I use treatment to get my boiler water to ~10-11, but the wet return measures around 5.5.
How is the boiler working? I would expect a lot of surging at that PH level.</p>
Things that I have seen affect it were other water quality issues (oil, possibly dirt, definitely other water treatments) and of course really high water level.NJ Steam Homeowner.
ChrisJ said: I don’t know the TDS of either but we are sending out water samples to the lab
Curious, What's your boiler water's TDS vs the feedwater TDS?
Is this Steam or Hot water?erussell58 said:This may be a question more suited to a chemist than anything but here goes…
My boiler feed water is approximately 8.5-9.5 PH. However, when I test the actual boiler water, I get a reading of 13-14. Any guess what may be going on?0 -
This is steam. Weil-McLain 688Derheatmeister said:This may be a question more suited to a chemist than anything but here goes…
- 128 Chimneys & Flues
