Combi boiler or boiler with indirect for domestic plus heating pool/radiant floor
tmachad2
Member Posts: 3
We have received a couple of quotes to replace our current geothermal that heats our indoor pool (28x 12 x4) radiant heat flooring in the basement and ensuite as well as our water heater.
1st one suggested a gas boiler (IBC VX 150) $ with an indirect water heater 40 gallon IBC ($). The pool heat exchanger included .
We would need to get an electrician for a panel and pool plumbing done separately
2nd suggested a combi gas boiler IBC SFC199 ($) includes electrical and pool plumbing plus and additional $ for a pool heat exchanger
just wondering your thoughts on pricing and equipment. Is the combi strong enough for a pool?
Thanks!!
Thanks!!
@tmachad2
This site has a strict no-pricing policy. Please remove the pricing from your post.
Providing more information about your project will be needed:
Tell us about your existing geo system, I assume it is loops, what size and model? What is wrong with it?
How many square feet of radiant? What climate? What are your hot water needs?
How is the air in your Natatorium being conditioned?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1
- 167 Indoor-Air Quality
