Calculating convector square footage?
johncreed
johncreed Member Posts: 3
What is the correct way to calculate convector square footage?
    Jamie Hall Member Posts: 26,616
    If you can't find the unit in Every Darn Radiator, you can come pretty close, but it's tedious.
    First, measure a fin -- length and height. Get the area Now measure the pipe diameter that goes through the fin and get it's area and subtract. Double the result, since the fin radiates on both sides. Count the number of fins per inch, multiply by the overall finned length, multiply by the area of one fin and convert to square feet.
    That will be close. It won't be exact, for a variety of reasons. But close.
  • johncreed
    Thank you very much.
  • Rich_49
    Rich_49 Member Posts: 2,783
    https://ocsind.com/products/cast-iron-radiator/
    Hit products , choose convector elements , choose your material
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
