Expansion tank noise
1928steam
1928steam Member Posts: 40
Another problem … the expansion tank is making a bubbling noise … it’s a hot water zone off of a steam boiler, closed system.  I had trouble with circulator pump before and oiled it.  Now the expansion tank which seems to be from late1998 is making noises, photos and video with sound to follow.
  • Ironman
    Ironman Member Posts: 7,858
    Is the hot water loop piped directly off of the boiler or through a heat exchanger?
    Bob Boan
  • 1928steam
    I cannot seem to post video but the noise is not dissimilar from popcorn popping, same irregular noise, just slower.
  • Ironman
    Can you answer my question?
    Bob Boan
  • 1928steam
    There is a heat exchanger visible in first photo, as well as pipe coming from boiler.
    here is another photo showing furnace
    hot_rod Member Posts: 26,592
    That type of sound is common when heat exchanger surfaces get scaled up. Also tank water heaters that have scaled up, sometimes called percolation. Like an old tea kettle.
  • 1928steam
    Any danger?  It just started.  How does one know if the expansion tank needs to be replaced?  Thanks!
  • 1928steam
    So the inside of the expansion tank can scale up like a hot water tank?
    Unusual to hear an expansion tank make noise, it’s just a vessel with a rubber membrane inside.
    Maybe the piping is transmitting the noise and the tank acting as an amp.ifier, a large surface area drum?
  • 1928steam
    No, definitely inside the tank.
    EBEBRATT-Ed Member Posts: 19,591
    Maybe you don't have any water pressure in the HW side of the system should be 12-15 psi your gauge could be bad.
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
    Please upload your video to YouTube or similar and share the link here. Thanks!
    President
    HeatingHelp.com
