Baseboard heater thermostat
HJLINT
HJLINT Member Posts: 1
Kitchen has two baseboard heaters on one thermostat. Thermostat has to be replaced. Need wiring help or diagram.
    Jamie Hall Member Posts: 26,769
    What kind of baseboard heaters? Electric? If so, what is the power (amps and voltage, or voltage and kilowatts).
    Is there a good reason why you can't simply replace the old thermostat with a new one of the same rating?
