Triangle tube prestige 110 hot water, but no heat
tuna
Member Posts: 3
My heater is 10 years old and I just bought the house a year ago. I have 3 solar hot water heaters on the roof. My heat has always been so hot, the thermostats are set at 55, and the house heats up to 75.
I just changed the motherboard and igniter. Now I don’t have error codes, but the heat is not switching from DHW. When I reset the system the valve opens and shuts back off.
Any ideas on how to fix.
My only suggestion is to read the manual very very carefully. It may take awhile to figure out that heat thinks that it is domestic hot water or some such thing (for example). Someone with ability will probably chime in shortly.0
Which controller does yours have? Picture?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
My parameters are all at factory settings. CH=01. I never had an issue with the heater staying on. I checked it this morning and the hot water was down to 82. I turned up a thermostat which started the burner, but still no heat going past the valve actuator.
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
