Setting High Limit on AquaStat
I have a 10 year old Honeywell L7224 AquaStat and I am unable to set the "High Limit" any lower than 180F.
  • STEVEusaPA
    Well if you’re doing right then the aquastat is bad, or you’re not doing it right.
    HVACNUT Member Posts: 6,874
    If you want to lower the high limit, you need to lower the low limit first. Keep 20° between the two.
  • dpsmith67
    dpsmith67 Member Posts: 6
    Device will not allow changes to low limit.  Automatically adjusts to a -15 differential from the HL temp.
    pecmsg Member Posts: 6,299
    https://customer.honeywell.com/resources/techlit/TechLitDocuments/68-0000s/68-0281.pdf
    Page 5
    Adjusting Settings
    To discourage unauthorized changing of Aquastat
    settings, a procedure to enter the ADJUSTMENT mode
    is required. To enter the ADJUSTMENT mode, press
    the UP, DOWN, and I buttons (Refer to Fig. 5)
    simultaneously for three seconds. Press the I button
  • dpsmith67
    Have tried going into maintenance mode.  Seems like the HL range is 180 to 220F.  Cannot change LL as it automatically adjusts to -15 of HL.  Everything works fine other than that.  Just trying to save money on fuel by reducing run time to high temperature.
    What are the numbers after L7224?
    There are probably different versions of the same model and yours isn't adjustable.
  • dpsmith67
     No number or letter.  Just L7224/L7228
